After a gas stop the unit came on with a white botton showing and amessage to push white button this went on for several minutes with the button moving around the screen. It then said that it was re-configured. The unit stated to show the road. Then it said that it was re-connecting to a satalite and asked OK. with a box to push this went on for several minute then the screen went black and the unit never tre-started
keep central heat off (botton on left push down botton on right push all the way up. Turn dialclock wise and either push in the little white button or pull out the "advencor". that button works the speed of the dial by turning it also
I believe the code has to do with the fuser unit. You can try to reset by pressing the "Yellow" Clear botton then the numbers "1""0""7" then press and hold the "Red" Stop botton till the display changes. Then turn the Main Power switch Off and then back On. If it will not clear you have a problem with the fuser unit and will have to be repaired to clear the code.
if the dryer runs when you push the botton in and stops when you stop pushing on the button you have a bad even heat board or a bad motor relay.these parts are located inside the top console,if you send me the model number i can look up your dryer and tell you the part you need to change out
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
The red button you pushed on the hot water heater was probably what is called a "piezo-electric" ignitor. It's normal for it to make a snapping sound and then pop back out. It sounds like you just lost the pilot light.
That being the case, do this:
Turn the gas valve on the hot water tank to the "off" position - it should be silver in color and down low on the tank. You may have to push it down to do this
Leave it off for about two minutes or so
Rotate the valve back on to the "Pilot" position
Hold down the pilot gas valve - it should be red and immediately to the left of the main gas valve.
While holding the pilot gas valve down, push the other red button to the right of the main gas valve - this is the piezo ignitor - push it several times in a row quickly
The gas pilot light should light
You can stop pushing the ignitor now, but continue to hold down the gas pilot valve (the one just left of the main gas valve). Let this valve up after about another 20 seconds or so.
Now rotate the main gas valve to the "on" position
Listen carefully - you should hear the main gas light and feel heat at the water heater flue outlet on top - don't touch it with your hand - you could get burned
If no luck, repeat the process until the heater re-lights
TIP - the instructions for re-lighting the pilot should be written on the heater
Just a potential diagnosis - the thunder clap, if as close as you describe, may have been intense enough to create what is known as a "draft inversion" that may have snuffed out your pilot light. The air pulse came down the flue pipe.
The reset on my son's CH-DVD 300 was the stop button. All i did was turn on the dvd player and then held in the stop button for 10 seconds. And badow, I have video.
