I have always had it connected. Now for some reason it will not connect even though I followed the directions and have been able to connect my tablet and my wireless printer
SOURCE: can not get kindle to connect to wireless or
You may need to enter your wep key.
wep key is a wireless key code found in your pcs router,Go to the routers home page and look under wireless settings.Somewhere on the kindles configuration you need to enter this code.
SOURCE: cannot connect to wireless network. have restarted
Hi!
I'm not sure if you're still in need of a solution but I'm currently going through the same issue. My Kindle 2 has not connected to Whispernet for over a week. I've been back and forth with Customer Service (1-866-321-8851 or 1-206-266-0927 if you're calling from outside the U.S) and after an exhaustive search for any possible answer, they told me it was a network connectivity issue and forwarded a service note to AT&T/Sprint, and promised to notify me as soon as possible. I'm still waiting to hear from them. Yesterday my Kindle connected to Whispernet for all of three minutes (just long enough to download a book I bought over a week ago) and now nothing. I've even tried switching wireless networks in range (go to settings, hit menu, type 311 - select different wireless networks) but to no avail. So basically, the best thing you can do after you have tried a soft/hard reset, a fully charged battery and toggling wireless off and on is to call tech support. Hope this helps!
SOURCE: I have a Kindle (wifi
You have to enter the WPA share key. The router password is only to access the built in administration web facility. The WPA share key is the encryption key necessary for the Kindle to connect to your router.
Testimonial: "exactly what I needed to know"
SOURCE: UNABLE TO CONNECT MY KINDLE
Four reasons come to mind that may prevent you from connecting:
Please add a comment to this solution if
one of these items resolved your problem. If you suffered from a
different issue I did not think of, it would be nice to drop me a line,
too. Other people will benefit from any experience you made.
SOURCE: My Kindle (version 3) suddenly won't connect to my
I found that with my doing a factory reset kindle 3 every so offen clears most of the buggy issues that arise after a few months of heavy use. I would say that a full factory reset would solve all software issues on any version Kindle. The downside is if you have uploaded your own ebooks (not purchased from Amazon) you most definetly will have to reload them. Not to mention settings etc. When all else fails try a factory reset works like a charm.
