Able to send messages to everyone but cannot send to my son who has the latest version Iphone. do not know what imessage means??
IMessage: The ultimate guide
https://imessageapp.net/imessage-online/
I found a whole guide about it. https://techmoxio.com/imessage-for-pc/
Every Apple device can send messages to another apple device. This messages are called iMessages.
When you try to send a message to your son's iPhone your iPhone will try to send it via internet using iMessages.
In order to "tell your iPhone" to use regular text messages make sure that your son's cellular number is correctly stored in your contacts. That way if your iMessage fails, your iPhone will send it via regular text message.
You will see the difference between both because the "send" button and contact name will turn green when using regular text messages and blue when you're using iMessages.
You have to do a hard reset I'm not sure how to on every phone, but on most "Hold volume up(while phone is on) and press and hold the power button(don't let go of the volume button until it powers back on and you see a funky screen) When it does power on use the volume to move up/down and power to select. There should be a hard factory reset option do that and it will fix any problem that you have. If you can't pull up the hard reset menu that way then google how to with the phone model and go from there. Good Luck.......
