KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer Logo
A
Anonymous Posted on Oct 04, 2014
<!-- from fixya rte -->Does it has an internal fuse - KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer
jfhinton45
Level 3:
  • Master 3,506 Answers
  • Posted on Oct 05, 2014
jfhinton45
Master
Level 3:
Answers
3506
Questions
Helped
1208816
Points
11472
I am not sure, often there is an internal thermal protector but easiest would be to contact the manufacturer or a serfvice center and ask the question.
1helpful
2answers
My Kitchen Aid mixer flashed a spark and banged whilst I was using it. The plug fuse has not blown but the mixer does not work.
Could be anything, but could be the switch, the electronics board, motor windings, the carbon brushes or worn insulation somewhere. Odd that the plug fuse didn't blow. It needs electrical diagnosis to find out what went wrong.
Service & Support Owners Center
KitchenAid https://www.kitchenaid.ca > en_ca > service-and-support
Make an appointment from our preferred list of service providers for service on your major appliances. ... Pro Line® Series Stand Mixers Stand Mixer Attachments ...
Oct 11, 2023 • Food Mixers
Stand cake mixer not working. No power when turn knob think water got inside. You think a fuse is out or something? Can it be fixed?
If your stand cake mixer is not working and you suspect that water may have entered the device, it's possible that a fuse or other electrical component may have been affected. Here are a few steps you can take to troubleshoot and potentially fix the issue:
  1. Unplug the mixer: As a safety precaution, unplug the mixer from the power source before attempting any troubleshooting or repairs.
  2. Let it dry: If water has indeed entered the mixer, allow it to dry thoroughly before attempting to use it again. Place the mixer in a warm and dry environment for a few days to ensure all moisture has evaporated. Do not attempt to use the mixer while it is still wet, as it can be dangerous.
  3. Check for visible damage: Once the mixer is dry, carefully inspect the external components for any visible signs of damage, such as burnt marks or loose wires. Pay close attention to the power cord and the area where it connects to the mixer.
  4. Check the fuse: Some mixers may have a fuse that protects against electrical issues. Refer to the user manual or consult the manufacturer's website to determine if your mixer has a fuse and its location. If the fuse is accessible, check to see if it has blown and replace it if necessary. Use the recommended fuse rating specified by the manufacturer.
  5. Seek professional help: If the above steps do not resolve the issue, it's advisable to contact the manufacturer's customer support or consult a qualified appliance technician. They will have the expertise and knowledge to diagnose and repair any internal electrical problems safely.
Jun 24, 2023 • Food Mixers
2answers
I have a hl200 mixer that wont start. What do I check
The power supply, like mains, plug and cable. then the on of switch or button. To check the motor, you have to open it, but I think you better leave that to a tech.
Jan 23, 2015 • Food Mixers
Have you an instruction manual for a ken wood mixer km265
make sure jar is in correct position and all the saftey items ok and fitted well.then no power?
ok maybe 1 bad wire (incoming power)
2 plug (check internal fuse)
3.power switch
4.trip switch (please check bottom side)
5.thermo fuse or by metel for protection.is bad.
6.all safty switches.
7 brush and brush holders.
8.coil.
please try and let us know.
Aug 20, 2014 • Food Mixers
Have a PVi8B mixer that has stopped working suddenly. Doesn't do anything when you flip the switch to "ON" are there fuses that could be the problem?
Does the blue power light come on when you switch it on? There is a 5amp fuse in the supply cable.Open the wall socket plug of the supply cable (unplugged of coarse) and check fuse and connections.With a multimeter check continuity of the three wires from the plug to the other end of the cable.If this is all good then you have an internal fault.There are fuses internally as well but this should be refered to a qualified technician.
May 10, 2013 • Food Mixers
Wooden spoon killed the motor!
these mixers use an electronic triac(to vary the speed of the mixer) of such low amperage that they run hot normally(to wear OUT), and they don't fuse the units electronics or motor anymore so anything that binds them will short out the triac or motor winding(from heat) and make them inoperable,try and order(what they call) an internal electronic part from these companies and good luck, I tried for 3 months and told them what I needed,they agreed this part was defective, but they wont sell you an internal part(LIABILITY ISSUE) unless your a "company certified technician" go figure, I finally got one through N.T.E.semi-conductors. and my customers HAPPY NOW!!!
My mixer motor doesn't work
check and replace the plug fuse and internal fuse of the mixer
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
