6 red blinking lights
Turn on green light 12 times then instead of 13th with light coming on, it 6 red blinking lights then brief pause then 6 red blinking lights. thermal fuse tested and working. wh
Thermal fuse and bulb are good. still getting code of 6 flashing red power light. what else would cause this code
If you turn it on and the, Power/Standby green light blinks slow 6 times; then it becomes a red fast blink 6 times, pause, then continues to blink red fast 6 times, again and again. this means when it's blinking 6 times is indication of electrical circuitry malfunction. The Television will need service.
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Hi, If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy. If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv. You will see 3 seconds long pause between blinks so count pause to pause.
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Hello!
When was the last time you replace lamp in your TV? If long time ago (2+ years) - replace the lamp.
If red light blinks in sequence (example 4 flashes, pause, 4 flushes, pause and so on) - then I need to know how many flushes between pauses. It is an error code. If it blinks just constantly - it is a bad lamp.
Regards.
Russ.
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem. How old is this TV and did you replaced its lamp? Thanks.
How many times red light blinks? It is error code of problem in TV. There would be pause of 3 seconds between blinks so count from pause to pause and let me know to find out solution.
