This machine was 12 months old and it has been two already that I am having a problem with the spinning.
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Regards
Phillip
SOURCE: Machine stops with SE code
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
SOURCE: samsung silvercare washer stopped working, won't unlock
here is the most common cause for this problem, according to the Samsung repair guy that was here to fix mine today.
On these washing machines it is possible for some debris (in my case it was a small screw from my packet) to make its way passed the drum and into the pump. Once this happens then the impeller of the pump becomes restricted or completely blocked which will result in the above mentione symptoms.
On some machines the pump is on the front, on others at the rear of the machine. In my case it was at the rear, removing the rear panel will allow easy access to it. Have a bucket ready, when the hose is removed from the pump the water will be draining from the machine. 3 bolts and a hose clamp on the inlet and another on the outlet hose. Disconnect the electrical plug from the pump and you can remove it from the machine for cleaning. A very easy job, requiring little skills and not much in terms of tools. (make sure machine is UNPLUGGED from AC outlet)
Remove obstruction(s) from pump and reinstall in reverse order of disassembly. The guy says these pumps are really tough so if you hear it buzzing, trying to go while it's jammed it's a good sign it will work. If not, replacement will be necessary.
Cost me $140. Could have been worse I suppose. Advise: Empty pockets BEFORE washing clothes...
SOURCE: When my Samsung Sensor Quick P801 800 washing
The machine can't balance the weight of the cloths.
SOURCE: The laundry is still wet after a normal wash cycle
Since it can spin by selector then there is no problem with the spinning mechanism. Need to call warranty service to address the electronic sensor control.
SOURCE: water not leaving machine
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
