Kitchen Appliances - Others Logo
Posted on Jul 04, 2009
Ccp-509 popcorn maker
The bushing that holds the stirrer inside the kettle is broken. on a ccp-509
adavis_NPG
Level 1:
  • Contributor 22 Answers
  • Posted on Oct 15, 2009
adavis_NPG
Contributor
Level 1:
Answers
22
Questions
0
Helped
26647
Points
52
Sounds like you need a new kettle. You can get a new one by calling 920-347-9122 for Nostalgia Electrics customer service.
How to fix this problem?
See if the gear at the top of the kettle rod is "jumping" and not allowing tehe stirrer to rotate properly. In my machine, this was caused by a broken black guide at the atop the two gears. The guide is screwed into place. It allows the gear to slide in and out as you rotate the kettle, but it also has to prevent the rod from moving back and forth or the gears will slip
4helpful
I need to order a kettle for my Old Fashion Movie Time Model CCP-509 and I don't know what size kettle it is and where to order it from??
Nostalgia Electrics CCP-509 Movie Time Popcorn Maker
  • Now for the finishing touch -- a full sized popcorn cart that makes delicious, old fashioned, movie house popcorn. The design is nostalgic, but the features are very modern.
  • Tempered glass window.
  • Large stainless 4 oz steel kettle with built in stirring system.
  • Warming light.
  • Kernel catcher.
  • Supplies compartment.
  • Safety Electrics, and easy to clean design.
  • Popcorn never tasted so good at home.
  • Makes up to 1.5 Gallons of popcorn per batch. 4 oz Kettle.
  • Storage compartment in base of unit.
  • Dimensions: 16"L x 19"W x 60"H
Ccp-509 popcorn kettle stop spinning when popcorn begins to pop. It won't pop out of the kettle.
Normally that is caused by too many kernels used. It pops too fast and jams up in the kettle. It could be a problem with the kettle though. Call 920-347-9122 for help with it.
1helpful
Need parts for the stirrer where can i find
You will have to purchase the kettle. It costs $40 and that includes S&H. Please call 920-347-9122 and they can take your order.
The washer that holds the stirrer. has pins
Sounds like you need a new kettle. You can purchase one for $40 from Nostalgia Products by calling 920-347-9122.
1helpful
Need new cord that plugs into kernal kettle.
The CCP-510BLK will use the same parts as the red CCP-510. For replacement parts, try calling Nostalgia Electrics at 920-347-9122.
Motor turns but gears seam to be slipping
I would look for screw that has loose up and that's proablly why the stirrer will not turn.
2helpful
Need Parts and a manual for Model #CCP-509
CCP-509
Go to;
http://www.nostalgiaelectrics.com/
click on 'customer service'
scroll to bottom of page.
at the field marked 'Enter Your Item #' enter CCP-509 and click on 'submit'
Scroll down again and click on 'Download User Manual'
4 0z kettle
Try their customer support page:
Top Nostalgia Electrics Kitchen Appliances - Others Experts
john h
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
