Washing Machines Logo
A
Annette Bell Posted on Oct 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IS THERE A SCREEN THAT HAS TO BE CLEANED MY CLOTHES DO NOT SMELL GOOD WHEN THEY COME OUT OF MACHINE
  • Mark Oct 06, 2014
    Hi Annette Bell, I want to help you with your question, but I need more information from you. What brand and model washing machine do you have? Some washers do have screens, but location is dependent on the brand and model.
    Thanks, Mark
GORDON'S APPLIANCE SERVICE
Level 2:
  • Expert 283 Answers
  • Posted on Dec 04, 2014
Expert
Level 2:
Answers
283
Questions
0
Helped
147294
Points
733
If yours is a front loader it's recommended to leave the door open when you're done. Also check and clean out the drain holes inside the lower area of the rubber "bellows". Use hot water and bleach occasionally to kill bacteria. If it's accumulated a buildup you can treat it with commercially available products.
2 Related Answers
Anonymous
  • 53 Answers
  • Posted on Jul 13, 2009
SOURCE: clothes don't smell clean
use good quality of washing powder
Anonymous
  • 389 Answers
  • Posted on Nov 18, 2011
SOURCE: bad smell in washing machine...clothes smell bad after wash
hi there is a build up of lime and old dirt in the inside of your drum the best thing to get rid of the smell is put a very small amount of bleach in the drum and put your machine on a very hot wash it will help in your hand book it will tell you to use your hot wash with a bit of powder and no cloths at leased once a month i dont know if you use your hottest wash most people dont these days because of the low temp powders, also the best product to use is lim away but you can only get it on usa bases or from the usa you might find someone on line that sells it that will get rid of all the lime thats been built up in your machine if you cant just use a bit of thick bleach hope this was helpful
1helpful
2answers
How come my clothes don't smell fresh?
Not the machine, stop using liquid soap. put machine through a cleaning cycle using a product like affresh.
We have just moved into a house and the indesit washer dryer makes the clothes smell off. Have cleaned out the drawer, cleaned out the seal around the door, put it on a hot wash with soda crystals, used a...
i knew someone that had that problem, and they said they ran vinegar through the washer. I dont know how true it was, but they said they never had the problem again.
2helpful
Samsung washing machine smells
the LE error code is an over suds error.
the smell could be coming from lint and foreign object matter collected in the rubber bellows that is conected to the drain pump this should be cleaned out i hope this helps
My GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Musty Smell
spray motor and gear housing surrounding with insecticide, roaches may be nesting there that gives out the foul odor
4answers
Stinky clothes
I have the same problem - the clothes smell like they have been left in there for a week - stale or moldy.
It only happens with dark clothes - I have started adding color safe bleach or oxy clean and sometimes a tiny spash of bleach - it seems to have solved it.
Clothes smell after wash cleaned filter still clothes smell
set the machine off on a 95c wash with no clothes or soap in, the most likely cause is a build up of soap scum on the inside of the drum, also try to alternate between washing powders and liquid tablets.
hope this helps
5answers
Moldy smell
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
Top Washing Machines Experts
john h
