Most chargers have a certain color light that should be lit when the charger is charging the batteries. If this is what you normally have had, the blinking light means the batteries in the chair are dead or disconnected somehow or the charger is defective. If your chair is still turning on you may have a bad connection somewhere or the charger is defective. If the chair does not turn on anymore the batteries may be to dead to charge. Also if it does not turn on you could have a blown fuse or something disconnected in the battery wiring harness that will not let the charger work.
