Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
A
Anonymous Posted on Oct 06, 2014
Touch pad does not function. Digital display lights are on but temp buttons do not work. ice auger does operate. Unplugged unit to see if it resets and it does not. I the touch pad bad or the circuit
Touch pad does not function. Digital display lights are on but temp buttons do not work. ice auger does operate. Unplugged unit to see if it resets and it does not. I the touch pad bad or the circuit board behind it?
4 Related Answers
Anonymous
  • 878 Answers
  • Posted on Sep 20, 2007
SOURCE: Blinking display
jph, this is a classic symptom of the high voltage board failure. What board did you replace? The high voltage board is the one on the back side of the refer, left hand side. Catriver.
Anonymous
  • 74 Answers
  • Posted on Nov 17, 2010
SOURCE: Front panel beeps when I push any button or
possible bad dispenser board
Anonymous
  • 794 Answers
  • Posted on Jun 03, 2011
SOURCE: Maytag refrigerator model # mfi2266aeu
Hi sandee462,
The reason why you experience this problem is because you have a control that if it senses the water is ran for over 2 min it shuts dispenser down , in order to unlock the control you have to reprogram it:
1. First, press the door alarm and freezer "-" simultaneously.
2. Release the door alarm but continue on pressing Freezer "-". You'll se PE_ _ _ _.
3. Press Freezer "-" until PE #### shows on the panel.
4. Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0".
5. Press Freezer "-" until PE and numbers blink.
6. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
7. Inside your refrigerator look for CODE #### which is at the right of the serial number.
8. Afterwards, plug back in your refrigerator.
9. Again you have to press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-".
10. Using the same method as above, enter the four digit CODE number you found.
11. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
Hope this helps.
Thank you for using FixYa.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Dec 10, 2012
SOURCE: I have a maytag ice 2O. Just replaced the HV control board, programmed with code 1411. All seemed well, but the icemaker turns the auger without prompting, and will not turn when the dispenser is depr
Did you put the correct code in? The code should be listed inside the unit.
Do i need a new Key pad or control unit
bad display control board
Mar 31, 2022 • GE Ovens
My samsung ice maker is making ice, but not dropping it, what can we do?
http://www.appliancepartspros.com/samsung-assy-cover-dispenser-da97-08118p-ap5651766.html
This is your Touch pad. On it using only two fingers (nothing else touching the fridge) Press and hold energy saver, and the lighting button at the same time for 5 seconds. All of the LEDS should flash on the display, this is error code mode. Hold it down until either all of the LEDs go blank, or unless one of the little temperature lines start flashing. If they do flash you probably need a new ice maker. If they don't, honestly, it still sounds like the control is still working because it's supplying the ice maker with power. If the display goes blank for 30 seconds, the fridge will reset causing it to start operating normally again, but it always feels good to see if the unit will actually throw the error code for you. DA97-08059A is the part number available here..
http://www.amazon.com/s/ref=nb_sb_noss/183-7769407-3742050?url=search-alias%3Daps&field-keywords=DA97-08059A
Before ordering this part, also verify the freezer is cold enough (-8 all the way to 10 degrees F will be cold enough for the fridge to induce a cycle of the ice maker, any warmer temps this will not work. If the ice maker doesn't solve the problem, Then we point the finger at the main board, but have never replaced the board on this model to solve this issue. These ice makers fail enough to keep a truck stock one at work.
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
Reset temp
To Change Temperature Control Setting with Touch Pads:
• Freezer setting is on the left side of the display.
• Fresh Food setting is on the right side of the display.
- Press the warmer or colder pad for compartment and direction desired.
- Present control setting number will illuminate.
- Each time the pad is touched, compartment setting changes one number.
A display of 1 is warmest and 9 is the coldest setting.
NOTE: Setting the controls to the 0 (off) position does not remove power to the light circuit.
Control settings will vary based on personal preferences, usage and
operating conditions and may require more than one adjustment.
Lights on front of refrigerator seem to be locked. nothing works when you push one but lights are on and the temp area states the same 39
You are looking at a bad selector switch and or the door switches that activate the auger to push the ice out. You would be looking at replacing the whole control if you need the ice to come out of the door. I would first try the simple unplugging and plugging back in, sometimes resetting the unit can help clear it up. Good luck
3answers
Please give me instructions how to use the Slushiemaker?
I have a schiller slush machine minus users instructions.
7helpful
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 • Ovens
GE Profile refrigerator, PSC23SGRCSS not working
I have the same problem with the same model. Did you ever find an answer?
Ice mover stopped working Kenmore model 363.9557710 purchased Jul 96
Yes....I can definitely see all your posts. Sorry I don't have a solution for you. :(
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
