Samsung 4.3 cu. ft. VRT Plus , Steam and PowerFoam Front Load Washer Logo
A
Anonymous Posted on Oct 06, 2014
How to reset the drain pump on Samsung vrt washer
John Emberley
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Dec 17, 2014
John Emberley
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
5
Helped
36679
Points
41
The drain pump is not something that you can simply "reset". If the overload device has operated "open circuited" and has not reset itself after cooling down, it will have to be replaced. It is located between the motor coil and iron. However, if this is the case, it may mean that you have a serious problem with your motor. And to make matters worse, if you have a problem with your drain motor, it may cause problems in your Control Panel.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jan 18, 2008
SOURCE: Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Anonymous
  • Posted on Sep 03, 2009
SOURCE: filter
I have a vrt ... I hope this helps.... Take of that little door on the front. Have a bucket or bowl ready. Bring down that little black hose, turn the white cap around and pull till it comes off. Drain into the bowl, turn the white filter cap counter clockwise to release some of the suction and wait till the hose stops draining. Remove cap, clean under running water w/ toothbrush. Manual says to make sure that the interior is free of anything (I wiped mine out) and then put it all back together again. Good luck
Anonymous
  • Posted on Jan 23, 2010
SOURCE: samsung vrt washer will begin cycle but get so far
You might have an object jammed in the pump housing. First thing you must do is to unplug the machine from the power outlet.You will then need to remove the back panel of the washer to access the pump. Disconnect the wiring from the pump and remove the two hoses by compressing the two clamps. ( Be ready for water to pour out of the hoses) Remove the three mounting bolts that hold the pump to the frame of the washer and remove the pump assembly. It is easier to work on the pump if you remove it from the mounting plate. Remove the three screws that hold the impeller housing to the pump motor. Seperate the two parts being careful not to damage the rubber o-ring that seals the unit. Inspect the impeller housing for any debris. (I found a nickle blocking the outlet port in mine). Remove anything you may find and reassemble in reverse order. The machine should reset itself and run as normal.
Anonymous
  • Posted on Aug 01, 2010
SOURCE: Considering the purchase of Samsung WF338 / DV338 Washer & Dryer
Don't buy any Samsung products. They're definitely not worth the money. We bought the front load 2009 washer and dryer about 14 months ago. Have always had problems with the dryer -- auto dry is a joke. The washer will not allow you to change the water temp. It's supposed to automatically correct the water temp; what a joke. AND the power went off today while the washer was filling with water, with clothes in the tub. No way to open the door, and we have to wait almost a week for a service call!!! IF YOU BUY SAMSUNG PRODUCTS, YOU WILL BE WASTING YOUR MONEY!!!
Anonymous
  • 43501 Answers
  • Posted on Aug 28, 2010
SOURCE: my samsung vrt front loader
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Samsung vrt front load washer WF218ANB/XA Burned up the drain pump. Installed a new one, now washer will work until the spin cycle. In spin cycle the door lock clicks and it will not drain or spin
Make sure the drain filter is not clogged. Most Samsung have an access door in the lower right hand corner to access and clean out this filter. If this is clogged or the drain hose is clogged, you will have these spin and drain problems.
2answers
Samsung WF210 not draining
Unplug the washer and check for all kind of clogs in drain hose and check for clog in hose from tub to pump and remove the pump and check for dirt and junk inside pump clean the pump with warm water and test pump for continuity as the pump running properly other wise replace it with the new one and reinstall it ,it should solve problem
Washer doesn't drain
This could be caused from a clogged drain/drain hose. Also there is a chance that the motor that pumps the water out of the washer could have failed as well
3helpful
3answers
Samsung vrt washer not draining
I've had so much issue with this washer since I've own it and it hasn't even been a year..I just finished fixing the same issue you have with your washer. I had to drain the washer which you were right very messy. My problem was one of the wire came lose. Of course it was from the water pump that was attached to the tub...Who would design something like that.
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
