Model# wrx735sdbm
I bought this size of refrigerator due small space in kitchen. Even it is smaller size it fits all my product i need to have in there. Great purchase.
Ice build on the freezer box floor or White frost build up on the freezer box back wall (inside). Ice layer on floor means your drain line blocked. White frost layer means your machine is not going into defrost cycle.
SOURCE: freezer drain line freezes up
Check to see that the thermostat setting are correct. If the freezer temperature is too low and the fridge section is kept high, then the cold air from the freezer does not circulate properly causing the ice build up in the freezer. The freezer compartment is where all the cold air in the fridge is created, and its blown from here to the other compartment by the evaporator fan. Ideally, the freezer should be about 10F and the fridge should be 35F. Remember that any changes in the thermostat controls takes upto 24 hours to take effect.
If you find that the freezer drain is freezing, you can try adding some salt to try to melt the ice. Or carefully poke through it using a chop stick or thin blade screwdriver. Be careful not to damage the tube. You can then flush this out with hot water.
You can even install a defrost drain strap kit to prevent drain freeze ups...In any case, I'd recommend that you get a profession to asses and diagnose the problem.
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
SOURCE: Whirlpool Side by Side Freezer - Ice Build Up in Drain
hi there,
common problem,several factors can be check,check your thermostat setting it maybe too low or you have defective thermostat,if you have good thermostat otherwise the refrigerant charge is to low there could be leak on tube,check your amper rating using clamp ammeter if you got low amper rating recharge freon,but why has low refrigerant there might be leak,repair the leak,before you recharge.hope this solve your problem have a nice day
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
SOURCE: Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
