Getting a weird code looks like EE without the top line on the 1st E
SOURCE: LE error code only top line missing?
You are right on the money. Had an extended warranty on LG from Best Buy and repairman was here this AM. Loose connection at thermistor. working fine again. You guys are a Godsend to many people... Thanks so much!
SOURCE: LG Tromm washing machine model WM2487HWM has an
That's 'te' standing for temperature error/ heating error. Before you call an engineer try emptying the washer then pouring a couple of kettles of boiling water into the drum and leaving for 30 minutes then see. Another thing is to empty a couple of packets of limescale remover into the drum together with a couple of kettles of boiling water (again!) and leaving overnight. It possibly needs de-scaling anyway ;-0) If these fail it will be an engineer call, sorry ;-0(
Good luck, John C
SOURCE: EE -error
That's a little 't' and it stands for heating (thermostat) error. It is possible that the heater is taking longer than it should to heat the water to the correct temperature. This could be that the element is coated in calcium. Although no promises (!) I suggest you run the contents of a couple of sachets of proprietary limescale removing powder/fluid through it. The most efficient way is to put the contents in an empty washer and pour a kettle of hot water into the drum then leave overnight. In the morning run just a spin; the water mix will then go through the drain filter and drain motor impeller blades, doing absolutely NO harm whatsoever, in fact some good! That can sometimes kick the thermostat into correct operation. You could also consider repeating the action ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
SOURCE: washer starts then stops and beeps after 30
Hello, Rochelle
I
am trying to help you out here. Maybe this will help some? I am know on
Fixya as the cleanup expert pro. Which means I spend my own personal
time to seek out customers that maybe have not had there problem yet
solved by the other fantastic great experts. I do this on my own for
free. Think of me as a Specialized Trouble Shooter.
I have found
out that it appears that lots of customers appreciate my efforts and
help. So, I thought I would take some of my own personal time to
see if I can help you. Even though this Informational site may not have
your exact model or brand, But this site will help you a lot. Here is
the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please
if this helped you at all, if you can find the time and in your heart
to rate my help and some kind words written would be appreciated for my
free help, I would appreciate it. Like I said I
just try to help, If anything this is good information for future
problems. If you felt that my free help was a waist of time for you, I'm
sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here
is also my direct link to my own pages of other areas of my expertise
for other problems you might have in Automotive, Appliance, and
Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Thank you for your post, friend!
I understand that your Frigidaire dishwasher is showing a "EE" error code. However, it appears "EE" is an invalid error code. May I have you model number please? Typically you can locate your serial tag (which lists your model number) on the inside of your dishwasher on the right hand wall. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
