Huge selection of Amana Washing Machine parts in stock. Same day ... A small leak in front of the washer could be caused by a defective pump. OEM Part ...
Find your parts fast and repair your Washing Machine with our free repair help. ...Admiral · Amana · ARDO · Asko · Bosch · Crosley · Danby · E-Wave · Electrolux · Estate ..... A small leak in front of the washer could be caused by a defective pump..... Washing machine door lock and switch assembly for front loading washers.
Hello, all the refrigerant most likely leaked out. To fix a leak it might be a bit expensive, sometimes to repair a leak will cost more than to buy a new unit.
We have the same problem for the second time in 2.5 years.
Six months (Dec 2005) after we bought the refrigerator, water was leaking from the door. Sears repair arrived and informed us it was the water tank leaking. Said it wa a known problem and was replaced at no charge (of course, we were also still under warranty - six (6) months out) --- FAST FORWARD 30 MONTHS (May 2008) --- SAME SYMPTOMS SAME DIAGNOSIS only NOW Sears wants to charge me $155 to fix the problem.
I'm gonna be calling and complaining about that!!!!!
Open your left door and look at the flat face under the bottom shelf (you'll see representative water drops). The water tank is behind this panel.
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
