Proscan 26LB30QD 26 in. LCD HDTV Logo
A
Anonymous Posted on Oct 08, 2014
How to fix a proscan tv/dvd combo no sound when tv on
Have sound when dvd plays no sound when tv is on
Level 3:
Top Expert:
  • Proscan Master 76,851 Answers
  • Posted on Oct 08, 2014
Proscan Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14965819
Points
237762
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jan 28, 2009
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Anonymous
  • 1779 Answers
  • Posted on Feb 26, 2009
SOURCE: Unable to get channels 14 through 98.
Make sure in the menu that you have the tuner set to Cable Mode, then auto program again. Hope this helps.
Anonymous
  • 49 Answers
  • Posted on Aug 18, 2009
SOURCE: Proscan 26LB30QD TV/DVD Combo, does not have an
unless you see a usb port in there my friend i think you might be out of luck i am sorry :)
Anonymous
  • 128 Answers
  • Posted on Oct 07, 2009
SOURCE: no sound when playing a dvd on a proscan lcd tv model 32LB30Q tv
Do you have a different audio source to test with (such as a tape player or vcr?) . That way you can verify if the DVD player is putting out audio versus whether the TV audio input is bad, or if the TV is configured to use HDMI for audio input.
Some TVs give you a setup menu option where the audio comes in through the HDMI port versus the (RCA) component ports. If yours is like that, then you should be able to switch that in the TV menu.
Anonymous
  • 62 Answers
  • Posted on Aug 23, 2011
SOURCE: I have the Proscan TV/DVD
Did ever worked properly?Is it wright one for unit that you have,you can check that in your owner manual,if not I will go back to dealer and ask for replacment.
Proscan Tv/dvd magnovox universal remote codes
Here are some Magnavox universal remote codes you can try to use with your Proscan TV/DVD combo:
  • 11963
  • 11603
  • 12746
  • 12260
  • 10587
  • 12070
  • 11990
  • 10178
  • 10030
To program the Magnavox universal remote to control your Proscan TV/DVD combo, follow these steps:
  1. Turn on your TV/DVD combo and point the Magnavox universal remote at it.
  2. Press and hold the "Code Search" button on the remote until the LED light on the remote turns on and stays on.
  3. Press the "TV" button on the remote to program the remote to control your TV.
  4. Enter one of the codes listed above using the number buttons on the remote. The LED light on the remote should turn off if the code is accepted.
  5. Test the remote by pressing the "Power" button to turn on the TV/DVD combo. If it works, try other buttons on the remote to control your TV/DVD combo.
  6. If the first code you entered doesn't work, repeat steps 2 to 5 with another code until you find the correct one.
If you are still having trouble programming your remote, consult the user manual or contact the manufacturer for assistance.
Have proscan tv/dvd combo unit PLEDV2488A. Volume not high enough. Is there a software update for this or some other fix?
Sorry but no. The good news is that you can add extra sound to make up for it with a surround sound system- a basic/inexpensive system is all you need- u get $100 all day every day!
1helpful
I just set up my new Proscan TV/DVD Combo & the sound is barely audible from my DVD's- Can this be fixed or is it a poor set?
The factory sound circuit is very poor, suggest you go on eBay and buy an inexpensive 5.1 Surround Sound system. You can use a computer 5.1 system by using the correct jack adapters and save some money. I use a LOGITEC system desktop computer system adapted for a flat screen and love it.
PROSCAN TV DVD COMBO WON'T PLAY BURNED DISC STATES "UNKNOWN DISC"
Yes, review the manual and find out what formats the unit will read. you then tailor your cd/dvd burning sw to that format. Also make sure the unit can understand and playback mpeg files.
Cant get the dvd to work cant put a disk in it a proscan tv dvd combo
Disc loading mechanism fault. Contact any service technician to replace it. This is not a user repairable fault.
I have the Proscan TV/DVD combo. The cable remote works for the TV, but NOT for the DVD player. And ever since I got cable, the Proscan remote no longer works (for tv or dvd.) Long story short, I have...
Proscan model number 19lb30qd, DVD will not play, lens has been cleaned. Are there replacement DVD players available?
judging on your brand of tv i wouldnt suggest pursuing a fix the cost could be close in comparison with a new tv if your ok with it buy a good quality dvd player to run into the tv im sure you would be happier than spending a pile of money only to end up back where you were ok hope this helps
1helpful
Proscan 37 inch LCD 37LB30Q Model
I used a swicher box form monster I plug in my viedo games and cable tv into it and then you run the composit cable which is high def into the tv but the sound into the swicher box the swicher box sound is run into the surround sound you just hit a button and you have the sound go to wall mart has the box for 20 dollars
2helpful
2answers
Proscan tv surround sound hook up
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
