Frigidaire ATF6000ES Front Load Washer Logo
Posted on Apr 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E20 error message
I am recving an E20 error message on my Frigidaire Affinity Front Load Washer, Model LTF6000FS0, yet my washer is is draining but it is not spinning. The motor is running but there is no movement in the tub. I had a repair guy come out and he moved some wires and it began to spin and it worked twice but I am running a load now and I am recving the E20 message and the tub is not spinning again. My washer is only 1.5 yrs old. The repair guy told me I may need a new control panel if the message comes back but that sounds expensive for a machine that is not even 2 yrs old. Any ideas?
johnny rebel
Level 3:
Master:
  • Master 604 Answers
  • Posted on Apr 22, 2017
johnny rebel
Master
Level 3:
Master:
Answers
604
Questions
0
Helped
136407
Points
2001
Replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
5 Related Answers
Anonymous
  • Posted on May 28, 2008
SOURCE: washing machine error code on Frigidaire ATF6000E
thank you larkinator.. that totally fixed the problem as far as i can see right now, I am letting it "wash" a load of nothing. it was a bunch of BS how they hid the filter... I had to literally take apart my whole machine. :-) but its fixed, THANKS!!!!!
Renee Stanfill-Marasco
  • 7 Answers
  • Posted on Jul 26, 2008
SOURCE: ERROR CODE E20
Just fixed mine, only I did not have to take it all a part. Just tip it over and reached in thru the opening in the bottom. Took the clamp loose with a phillips screwdriver and pulled the rubber off that contains the filter. Stuck my hand in the opening and pushed up on the filter from the bottom on the rubber container. Out came the filter and I cleaned it and pushed back down inside until it was past the lip that held it in place. Works great, took about 10 mins., not bad for a woman, huh. Thanks for the info, could not have done without your diagram and information.
Anonymous
  • 2712 Answers
  • Posted on Oct 04, 2008
SOURCE: Frigidaire Affinity E20 error code
Check this answer:
http://www.fixya.com/support/t615626-error_code_e20
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Anonymous
  • 208 Answers
  • Posted on Jun 22, 2009
SOURCE: I have a code E20
bad pump
Mukesh Kumar
  • 3230 Answers
  • Posted on Jul 24, 2009
SOURCE: e20, slow to drain frigidaire atf7000fs
probably has something stuck in the electric drain pump happens alot on frigidaire washers it is accessable after removing front lower acess panel tilt washer back after pulling it from the wall the drain pump will be just right of center at the front use a pan to catch any water that will come out you can either remove the 2 drain hoses to clear obstruction or you can unscrew pump motor from pump body
Good Luck!!
Thanks.
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
How can I fix E20 error on washer
COULD BE EITHER? U HAVE TO CHECK THE HOUSE DRAIN AND THE HOSES AND WATER PUMP FOR OBSTRUCTIONS
Code E20
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
1helpful
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
1helpful
2answers
E20 error, but isn't spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
10helpful
Error code E20
Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may not spin.
So i would first look for a clog in the hose right before the water pump there is a little cup in the black hose that could be full of suff if so empty the cup and it should work good after this
hope this will help you out
Best regards Michael
1helpful
My washer will not spin and posts E20 error
E20 means that there is a clog somewhere in the drain line. Check the hose, check the check valve at the pump, make sure nothing is clogged or stuck. It should not take you that long to find the problem.
3helpful
2answers
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
1helpful
E20 Error
On the sheet, 2 beeps and error E20 says Water Doesn't Drain. Drain hose is kinked or household drain is clogged. Straighten hoses or unclog household drain.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
