Check engine ecu light keeps comming on 2006 volvo Cummins isx
We can provide Volvo and Cummins engine power generation. Volvo power range is from 68KW to 600KW
Cummins power range if from 24KW to 2500KW
Volvo Generator Volvo Generator Set Supplier and Manufacturer in China
Cummins Generator Cummins Generator Set Supplier and Manufacturer in China
Can you read the diagnostic codes in the dash of your Volvo truck?
Follow this link it will give you a breakdown of all of the Volvo fault codes.
http://www.advantagetruckparts.com/pages/truck-repair-diagnostics.htmls
Get OBD (on board diagnostic) from auto zone and plug it into car to read error codes.
SOURCE: i have 05 volvo vnl 670, isx cummins 450/500.
I have a 2007 Volvo 670. The check vehicle ecu comes on. The fault code is MID 144 PID 191 FMI 5. THe truck won't go pass 1400 rpm, the speedometer doesn't work, the cruise doesn't work, the engine break doesn't work. I have to turn the truck off going down the road at highway speed for about 10 seconds and it'll go back to normal. Can anybody help?
