the refrigerator is what cools the water so if that working than the water should be somewhat cold unless you dispense a lot of it. Otherwise its a bad design by the manufacturer.
Is there a coil of tubing inside the refrigerator? This is how they usually cool the water. If you use a lot of water through the dispenser, the water will become warm.
If this freezer is like most, the water going to the dispenser is looped around many times in the refrigerator section near the back. Make sure that this is still true. It must have a lot of water cable in the refrigerator section so that the water has time to cool down before it goes out the dispensor. If for some reason the water tube is touching either the compressor motor or another hot part of the external refrigerator it could cause it to be to hot to cool down in time during its travel through the refrigerator as well as it will start to warm up the refrigerator section as well.
Also, I am sure you have tested, but make sure that you are plugged into the cold water supply and not the hot water supply. Check the water at the connector and see what the temp is at that point before it enters the refrigerator.
My guess is that the coil of water tubing that is usually in the back of the refrigerator section has been either lessend in length or the water entering the refrigerator is too hot to be cooled down in time before it reaches the dispenser.
If this is a new hook-up please be sure that your water line is connected to the cold plumbing on the house and not the hot. IF it is on the hot the fridge is cooling it down to warm.
not dangerous, i would recommendvacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Usually the coolness comes from a large coil of plastic tubing in the refer compartment that stores the water. Check that the refer compartment is cool enough. Also see if running a large glass or two becomes cool again and stays cool for a while. Usually the very first 1/2 glass may be warm until the "cool" water that is stored in the coil of tubing finally makes its way to the dispensor.
