Ford 8N Tractor Logo
A
Anonymous Posted on Oct 08, 2014
Tractor will not start
Tractor will not run when it starts it will not stay running
Rob Woolcock
Level 2:
Sergeant:
  • Expert 289 Answers
  • Posted on Oct 08, 2014
Rob Woolcock
Expert
Level 2:
Sergeant:
Answers
289
Questions
Helped
69620
Points
733
Could be sucking too much air
My lawn tractor will not start unless I jump the solenoid with a screw driver ? Then it will stay running ...
Sounds like the ignition start switch is defective and making poor contact. or the harness to it is loose or has corrosion.
Oct 28, 2016 • Garden
Cranks over but won't stay started
Unhook your fuel line from, fuel should run out
1helpful
When I push and hold the start button the tractor starts and stays running, if I release the start button it shuts off, if I remove the wire to the solenoid relay it stays running
It sounds like a "Load Resistor" problem, not sure if you have this type of starting system. The load resistor is in the wiring that goes to your coil after the engine has started. It is bypassed when starting to offset the loss of voltage when the starter is engaged and turning over the engine, then after the engine has started the "Load Resistor" is again in series with the points dropping the voltage slightly and providing longer point life. If this resistor burns out then you would be able to start the tractor but as soon as you released the starter foot switch the points/distributor would no longer have voltage. The Load Resistor is a large gray, brown or white colored rectangle ( 3" long and about 1/2wide aprx.) mounted on the back side of your dash panel....
My MF1528 won't start or stay running?
Try Goggle it. To get manual. The seat deal is doing what its should,
May 02, 2014 • Garden
Small farm tractor starts won't stay running
sounds like the carb has some bad gas in it or it may have some trash in it plugging up the jets
Tractor
be careful with starting fluids, they strip cylinder walls, NOT a good thing. Prime with WD 40 or gasoline. forget the starter fluids. In all likely hood your carb needs cleaning. Pull the fuel line off the carb first though, and crank the engine. If you get good fuel flow, you just have a plugged fuel filter.
I cant start my leaf blower
I would suggest a new plug and fresh gas and oil mix.push the primer bulb 8-10 times and turn choke to full.pull cord about 4 or 5 times until it starts.if it don,t stay running turn choke to half and pull cord until starts should stay running.let run for about 10 seconds then turn off choke.Almost forgot that during this whole process you hold throttle wide open.
Dec 08, 2010 • Garden
3helpful
John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
Top Ford Toys Experts
Kardoc
Paul Katynski
Paul Katynski
Are you a Ford Toy Expert? Answer questions, earn points and help others
