There are certain situations you need to put your iPhone in recovery mode. Perhaps it freezes, it keeps restarting continuously, it is not being recognized by iTunes or you were attempting to jailbreak it (or you already did) and need to restore it to its original state. Whatever is the reason, putting iPhone in recovery mode will allow you to restore your device while at the same time getting rid of these issues.
However, do you know that you'll lose all the data on your iPhone when you perform a recovery mode restoration? Please make sure to backup your iPhone before restoring iPhone. If you've taken a back up of your device using iTunes or iCloud, Fonedog iPhone Data Recovery can help you to restore iPhone from backup.Follow the steps below on how to put iPhone in recovery mode.
Step1:Download and Launch FoneDog Toolkit- iOS System Recovery
Step2.Download Firmware Package for Fixing iPhone Recovery Mode
Step3.Repair the iPhone Recovery Mode
More Info:How to put iPhone in Recovery Mode
Hope it can help you!
Try putting your iPhone in recovery mode.
follow the link to see all the information you need.
Succes! How to Put iPhone into Recovery Mode
SOURCE: iPhone
Hello Bruce,
Try this first:
Press and hold the Sleep/Wake (on top of the iphone) button for a few seconds until the red slider appears, then slide the slider. The phone will turn off. Then, push and hold it again, until the phone comes back on.
If that doesn't work, try this:
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears. This will do a "hard reset" and should bring your iphone back to life!
Please let us know how this works for you.
Best regards,
Bill
SOURCE: help! bricked iPhone
go to modmyifone. theres a tutorial on there which i found very useful or even better still. follow the link from modmyifone to brooksgarrets blog. he breaks down the process an even puts it into lamen terms
SOURCE: logo itune and no servise
If the iPhone is brand new, it has to be activated using the iTunes software on the pc, plug the iPhone in and follow the guide.
as for the iPhone saying no service and insert SIM, the iPhone will only work with O2 (UK) and Verizon (USA) unless the phone is unlocked to be allowed for use by all carriers.
if you find out that the phone isnt unlocked you will need a SIM Card for either O2 or Verizon Depending on which country you're from !
SOURCE: iphone only see apple logo and itunes logo in a dark screen after
If it got wet, you can bring it to any Apple Store. Nine times out of ten they will replace it for $150 to $200 dollars. Unless they determine it is a manufacturers defect and you are still under warranty, then you want have to pay anything. they will usually just replace it for you.
Otherwise, you may have to pay up to $200 for a replacement.
Hope this helps...Let me know...
enov8
SOURCE: iPhone not charging, not recognized
You need to restore whit the last version of iTUNES and an ofiial firmware. Then apply jailbreak.
