If being robbed at an ATM machine, if you use reversed PIN# is this an automatic alert to police?
SOURCE: Resetting Pin on Blue Hat ATM machine
Hi abbeybath,
We have the same atm/bank for our son. Here's the fix:
1 - push the reset button on the back of the ATM near the battery compartment.
2 - insert the ATM card and press the BALANCE button to change the user name (need to do this before getting to the pin)
3 - enter your childs name and push enter when complete. Cancel will delete an incorrect letter.
4- enter the default pin (1234) - this will bring up the DEPOSIT, WITHDRAWL, BALANCE screen.
5 - Press ENTER and it will show the current/default pin. Input the new pin number you desire and press ENTER again.
All set. Hope this helps!!
SOURCE: I need a replacement 6 pin rocker switch for
try electrosonic if in canada
they carry wide range of eltronic parts
but a simple 6 pun rocker can be bought ar radio shack or local electronics store
just remember if you need it to auto center it's easy to find if you want it to stick 1 way or other then you will have to modify the switch
SOURCE: Summit Products Youniverse Deluxe Atm
Remove the batteries and it will reset to 1234
Once the screen displays "withdrawal" "deposit" press the enter key twice. The red light should blink each time pressed. Then put in your new code and press enter.
You can see the toymaker's website here.
SOURCE: proteam atm machine no HO1912 does not give
All a load of rubbish . No enter button and the password is only 3 digits. All talking ****
