Question about Duravit Duraplus, Two-Piece Toilet - D13018
<!-- from fixya rte -->Duravit toilet cistern fills slowly - Duravit Duraplus, Two-Piece Toilet - D13018
    New Friend:
  • 64 Answers
Make sure the toilet shut off is all the way on (if there is one) replace filler valve and should fill quite quickly.
Posted on Oct 14, 2014
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: my toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Posted on Oct 31, 2009
Anonymous
SOURCE: I have a Duravit toilet with a Geberit flushing
i think you have a snake in your bathroom lol
Posted on Apr 26, 2010
nzcoops
  • 5 Answers
SOURCE: cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Posted on Jul 02, 2010
The cistern would not fill up. How do I remove the lid to look inside?
This guy's video tells you how to service the parts:
For me the problem turned out to be that these gears got misaligned at some point. The blue piece should be "locked" into this position. If the white gears are not aligned correctly they will get stuck and the seal at the bottom (the flapper) will not slide freely down all the way.
Oct 09, 2013 | Duravit 0910100005 Happy D Toilet Cistern ...
Replacement button needed
HI, Duravit spare parts can be a nightmare to find, and my best solution to you would be to unscrew the push button from the cistern lid. Take it along to your local plumbers merchant who will more than likely have a suitable non-genuine part that will work just as good.
Jan 14, 2011 | Duravit 0910100005 Happy D Toilet Cistern ...
Why is it oveflowing continuously?
maybe your fill valve need adjusting, or replacing, or the flush valve is bad your question is a little broad so it is hard to pinpoint
Jun 29, 2010 | Duravit 0910100005 Happy D Toilet Cistern ...
After cistern refill outflow into toilet bowl continues to dribble in - and you can see a slight flow into the bowl and every so often we hear the cistern refilling a small amount to compensate.
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
Nov 15, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
Cannot remove top of cistern
Oct 29, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
When cistern fills with water it leaks into the bowl
This is caused by the 'syphon' mechanism sticking, quite often nowadays the 'brilliant' plastic push button/ syphon combo sticks, and most toilets are fitted with an internal overflow, lift the lid on the cistern and check for anything causing an obstruction.
More often than not, it's a tiny bit of scale that causes such a headache, and the fact that nothing is made with any quality nowadays!
If you can't see what's wrong call a plumber, he/she will solve it.
I hope this helps
Steve
Jul 09, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
How do i get the top off of my duravit toilet??
try to check if there is any screw on the side of pulling knob...try to pull it and chek around it...good luck!
best rgds Stefano
Dec 27, 2008 | Duravit 0910100005 Happy D Toilet Cistern ...
Maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Duravit Duraplus, Two-Piece Toilet - D13018 Logo
328 people viewed this question
Top Duravit Home Experts
Marvin
Marvin
Paul Carew
Lawrence Oravetz
Are you a Duravit Home Expert? Answer questions, earn points and help others
