I just finished connecting the Pioneer Car DVD player, when completed, I reconnected all A/C connectors, hazard connections, and misc. connections. When I powered the car, I noticed my A/C is no longer powering on. I disconnected the wires again, and reconnected them again and still its not working.
SOURCE: how do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
SOURCE: NO POWER TO PIONEER HEAD UNIT
Disconnecting the cables shouldnt have hurt it. Make sure you got the plugged back in ALL the way and try again. Post results here.
SOURCE: avh-p6600
similar but not exactly the same - for a dvd you must also connect a line to the parking brake wire that shows ground when engaged
SOURCE: problem wirings for Pioneer AVH-P6500DVD Car DVD Player
very easy fix. you can pay thirty bucks on ebay and buy the bypass kit or make it yourself. but the light green wire on the harness has to be hooked up to ground. just hook the light green wire to the chassie of the car and you will be able to see dvds all the time. If you want to buy the kit its not really needed I have a toggle switch on mine just for turning it on and off when I am driving. simple as putting a wire from your chassie of the car(Ground) and then the other from the unit(light green wire) to a switch. hooking it up from Supply to Acc on the switch.
SOURCE: Pioneer AVIC-N3. What wires power it on??
the pioneer avic n3 has a seperate brain system and there is a cable that hooks the two together its called like the 13 pin wire or something and once you hook the brain and the head unit together it will have the display and everything else
