In cleaning my gas-fired Marco fireplace, unsure original base configuration, mine has only burned out mineral wool pieces. The metal flat base has a row of small ports along the front. A single row of...
Unfortunately, you didn't list the model number of your fireplace and whether it's vented or vent-free. However, I suspect it's vented, as MARCO (now out of business) manufactured very few vent-free models. Restoration is going to depend on the condition of the burners, as well as the gas control valve and the condition of the firebox. The small ports you mentioned, are for the Rock Wool (Glowing Embers), which are divided into small pieces (dime size) and fluffed, then placed over the small ports. MARCO did not make a vented fireplace where silica sand was used on top of the burners. Normally, you only see that on vented gas log set, that is installed in a solid fuel burning (masonry) fireplace and operated with the damper fully open.
As far as restoration parts are concerned, I seriously doubt there are any available. MARCO, as such, has been out of business for almost 10 years. Today's burners are not designed for the same configuration that you have. It wouldn't be wise to try to change the configuration, as the firebox was tested and approved for only what's in there now.
Wish I had better news for you. But, my 15 years in the hearth and home business, tells me it would difficult and costly to do.
