Lost my instruction manual to my ge universal remote model#jc024 to program my Santo d925204
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: I need to program ge universal remote jc024 for
I also lost the manual for my GE JC024 Universal Remote. I remembered though that you just hold in the button for the device you want to program and the "SETUP" button at the same time for about 5 seconds until the red light on the remote flashes and stays lit. then let go of the buttons.Then you basically just press and let go of the on/off button, pausing for a second or two in between presses until your device turns off. then you have to press the "ENTER" button and it'll store the code for that device. This method just cycles thru all of the possible codes for that device. sometimes you get the wrong code and the remote wont completely work. like hitting the volume button makes the tv mute for example. just repeat the steps until the device turns off again and eventually you should be able to get it. hope this helps.
