SOURCE: My phone won't quit ringing
Keep looking under Terminals and Sets for your extensions. Lines either Appear or Appear and Ring.
Carl
SOURCE: Require remote ring light for Nortel T7316E
What cabinet are you using? The CICS cabinet has an Analog Terminal Adapter built in (ext 117 or 37 iirc). This puts out a standard ring voltage that you could use to feed a strobe or relay. I hate to bring this up, but there is also an Auxiliary Ringer port on the sytsem. It's a make contact designed to handle 50 mA at 40v DC. You can drive a slave relay and switch whatever you want. It's assigned to a line or extension in programming. The only reason I hate to bring it up is because it makes your vendor look stupid, which he probably is. Carl
SOURCE: How do you get a t7316e phone to ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
SOURCE: Have the Nortel T7316e. Before the phone rings it
Here is a link to your phone manual.This site is SAFE and requires Adobe.I use it all the time,have no problems,and is very useful.Although I have read it,you know more about your phone's functions than I do.After reading the entire thing,I am referring you to a few possible solutions which may enable you to accomplish what you are requesting.Under your T7316E telephone,letters C and H have potential.A section labeled Button inquiry also has potential.Also,under programming memory buttons there is an option for features which does not seem promising but with current technology you just never know.lol.Good luck! Greg I hope this really helps.If not,just comment here and I will get an autolink to your post and will reply ASAP.P.S.You do not need to enter an email,it will download.
http://www.retrevo.com/d/ds/progress?doc=7fe12a0d8b82e6e63f8c28dc321b7d4e&rk=0.5900604098041088
http://www.retrevo.com/support/Nortel-T7316E-Telephones-manual/id/2877ci958/t/2/ there is a manual and trouble shooting
