Keurig Special Edition B60 Coffee Maker Logo
A
Anonymous Posted on Oct 09, 2014
Where can I find funnel for keurig b60 coffee maker
Funnel was missing and they say it's been discontinued
Eric Morris
Level 2:
  • Expert 75 Answers
  • Posted on Oct 11, 2014
Eric Morris
Expert
Level 2:
Answers
75
Questions
Helped
17393
Points
136
Ebay , type kuerig b60 funnel
5 Related Answers
Anonymous
  • Posted on Feb 28, 2010
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
cmccune04
Clayton McCune
  • 214 Answers
  • Posted on Apr 13, 2010
SOURCE: Missing Keurig part
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
cmccune04
Clayton McCune
  • 214 Answers
SOURCE: where can I find a K-cup Portion Pack holder and
cmccune04
Clayton McCune
  • 214 Answers
  • Posted on Apr 14, 2010
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
tgmusicgirl
Lisa
  • 101 Answers
  • Posted on May 06, 2010
SOURCE: How do I clean my B60 Keurig of scale
Empty the water...
start with half distilled water... half white vinegar...
just run it all day... take a break and let the vinegar work... it will be heated up in the main tank... then pushed out to all hoses and sensors etc.etc...
enpty the container... wash it out... fill it with filtered or distilled water and run that until you no longer taste/smell the vinegar...
consider buying a brita pitcher and use that water for your Keurig... I do... and my unit goes for a long long time before it needs a vinegar washing...
P.S. dont use C.L.R. :(
It tastes bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Testimonial: "Thanks so much for the help. I already use Brita filtered water, so it's good to know I'm on the right track!"
1helpful
2helpful
3answers
I need a replacement K cup holder system for the Special Edition Brewing System
i think you are talking about the black funnel part, the replacement k cup holder, i know of this great site that sells all kinds of replacement keurig parts i hope this helps http://stores.ilikenew.com/-strse-14/coffecoffee,-tea,-shakes,-diet,/Detail.bok
I am looking for the funnel.
Check Ebay for this part. I have seen them come up several times.
1helpful
2answers
Where can i get a new k-cup holder
the black funnel part? if so, check out this site, http://stores.ilikenew.com
2helpful
2answers
K--cup holder (pod holder is broken need another
if you are talking about the black funnel part? then this site sells them http://stores.ilikenew.com
Broke a piece of plastic off funnel when taking apart to clean.
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Weak coffee
Have you de-scaled and rinsed your Keurig?
Two things more you should look after: Boiling temperature and cleaning the funnel and exit needle.
Instructions here:
http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
1helpful
Coffee isn't dispensing properly
You're using K-cups right?
Check if the funnel or exit needle is clogged up.
If you haven't de-scaled it for the last 4 months, try to de-scale it and rinse it with clear water and no K-cups.
Information here: http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
