SOURCE: Lines through negative scans
Clean the glass surface with Iso propyl alcohol (Industrial grade is enough). Dont use any solvent. Just for immediate usage, you can use your aftershave and clean. Clen with a soft cloth.
S. Mohan, Chennai. India
Open the scanner software on your computer. Put it in Professional Mode. Go to film type and select Positive.e
SOURCE: Epson 2450 Perfection Photo Scanner
The Epson film holders hold the film 1 mm (.039") above the glass scanning window. You could cut and glue 1 mm plastic sheets to make your own holder if you can't get the originals from Epson. I'm making one now that will hold more than a single frame of 120 film, which is all the original Epson holder would take.
