Food Mixers Logo
A
Anonymous Posted on Oct 10, 2014
Take apart kitchenaid dicer
Clean dicer
John Fink
Level 2:
Champion:
  • KitchenAid Expert 202 Answers
  • Posted on Mar 16, 2015
John Fink
KitchenAid Expert
Level 2:
Champion:
Answers
202
Questions
0
Helped
113237
Points
273
One of these two Service Manuals will, most likely, give you the answer:
Professional 5/6 quart
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
Classic 4.5/5 quart
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Why doesn't it turn on after cleaning and reassembly?
Yes it is everything to do with the side springy things. Get a torch and look inside there is a blocker on one corner, it needs to be lined up with the missing corner on the carbon brush.
Change oil kitchenaid mixer
They do not have oil in them, it will be the grease breaking down. It is food grade grease so not at all harmful. If you want to replace the grease you will need to pull the mixer apart and clean out the old grease and purchase some new grease from Kitchen Aid, a very messy job.
Kitchenaid mixer K45SS only has one speed, slow. Have taken apart and regreased the machine. I plugged it in while the planetary head was off and it went through the speeds as normal, but as soon as
Did you clean the are around the variable-speed control lever?
Please be sure to unplug the mixer BEFORE disassembling the mixer.
http://www.ereplacementparts.com/kitchenaid-k45sswh0-classic-stand-mixer-parts-c-114958_114959_115060.html?page=4
http://www.ereplacementparts.com/article/11983/How_to_Replace_the_Speed_Sensor_and_Control_Board_on_a_KitchenAid_Pro_6_Mixer.html
Motor clicks every turn
The clicking is probably a small nick in one of the gears, even the smallest chip can cause alot of noise or make the mixer click. Is the beater shaft still turning when you have a load in the mixer (bowl is full)
Or is it just clicking?
If the beater stops turning it is going to be caused by stripped gears, however if it is just clicking this would indicate just a nick in the gear. Either way I would recommend opening the mixer and replacing the damaged gear/gears.
Your mixer is considered a 5 Quart Professional, which means it has the same parts as a KitchenAid 6 quart mixer. The first thing you will want to do is take the mixer apart and disassemble the gearing. You will want to clean off the gears with paper towels and wd-40. Carefully inspect each gear once clean and replace damaged gears.
In the professional mixers when a gear strips you need to replace the grease and housing gasket, this is because the gears are all metal and there may be metal shavings in the grease which could cause the gears to strip again.
The most common gear to go bad in the Professional series mixers is the Worm Follower Gear (9706529). Here is a link to that gear on our website: http://www.mendingshed.com/wormfollower.html
Also, here is a link to the service manual for the mixer, this will aid you in taking the mixer apart and putting it back together correctly. http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
We are one of KitchenAid's largest service centers within the US, and all parts we sell are genuine KitchenAid products. All parts are available at our website, www.mendingshed.com
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
1helpful
Oil leaks out when tip up .around
KitchenAid uses a vegetable based grease inside of their mixers, it is a food safe grease. Because of this if you do not use your mixer often and over time the grease inside the mixer can begin to break down, and an oil will leak from the mixer.
What you will need to do is take the mixer apart, clean out the old grease and replace it with new KitchenAid grease, it is also recommended that you replace the gearbox gasket.
We are one of KitchenAid's largest service centers in the US, everything we sell is Genuine KitchenAid replacement parts.
Here is a link to the grease on our website: http://www.mendingshed.com/kagrease.html
And a link to the gearbox gasket: http://www.mendingshed.com/mixergasket.html
Also to aid you in the repair here is a link to the KitchenAid service manual for your mixer. this will show you how to take the mixer apart, replace the grease, and reassemble the mixer. http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
I have a new kitchenaid mixer and both times i've used it the cake did'nt come out right, it was bland and it fell apart and that never happened before. what did I do wrong?
It could be that your over mixing the batter. It is very easy with a KitchenAid to push a batter too far, and you get too much air, or cream the butter too much into the flour, or press all the oil out of peanut butter. Try using the mixer for only as much to get the matter mixed.
My mixer worked fine, I took it apart for a really good cleaning and now it won't work at all. Please show me how to take it apart & put it back together correctly.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers your model. Pay attention to the Motor Brushes, making sure
they are maiking contact with the Motor after re-assembly.
1helpful
2answers
I need a manual or parts diagram (either would help) for the power dicer attacment used with #12 hub on a Hobart mixer
I think you'll find what you're looking for here.
http://www.hobartservice.com/Parts/
Select "Hobart SmartParts" Then "Food Machines" <continue>, "Power Drive and Accessories" <continue> and your Power Dicer option will be available.
Hope this helps.
Put kitcheraid meat grinder back together
Proper assembly of the Food Grinder Attachment is covered in the attachment's Use and Care Guide.
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
