Column a is hidden. need to unhide it.
The solution is slightly different depending on the version of Excel. For Excel 2007 here are details:
http://www.techonthenet.com/excel/columns/unhide_cola2007.php
SOURCE: MS Office 2007 Installation issue -- need help with error message
this usually means it can't find the file on the CD/DVD, either the CD is dirty or bad, clean the disk and try again,
thanks for rating
SOURCE: I have over 10,000 2003 or earlier MS office Excel
Try to install Office file converter pack from http://www.microsoft.com/downloads/details.aspx?FamilyID=CF196DF0-70E5-4595-8A98-370278F40C57&displaylang=en
SOURCE: MS EXCEL
Click on the space above the first row header and on the left of the first column header. All cells on the sheet are selected now. Ctrl 1 to open the format cells dialog. On the protection tab uncheck locked.
After you do this select the cell you want to lock. Ctrl 1 to open the format cells dialog. On the protection tab check locked.
SOURCE: what is the last column name of excel
I think there's no specific name for that column, but we can say it's A1048576.
SOURCE: I'm used to using Excel 2007. I bought a new
Select the column. Click Format, click cell, click number, select the date format you want, click OK. Done.
