Xerox Phaser® 8550, 8560, 8560MFP Extended Capacity Maintenance Kit, 30,000 Yield, Part Number 108R0... Maintenance / Upgrade Kit Logo
J
Julie Bailey Posted on Oct 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does Xerox phaser error code 8560 09 005,40:27220 mean?
My Xerox phaser 8560 stopped printing in the middle of a print run and is displaying error code 8560 09 005,40:27220 Any ideas how I can fix it?
  • Julie Bailey
    Julie Bailey Oct 11, 2014
    After a power-off, it's now displaying error code 09,035.43:27220.
  • Julie Bailey
    Sorted what the error code means, there was a broken ink stick in the shute. Cleared this, but it now needs the error message cleared. The manual says Run Clear ISC Fault test to clear the error. The Clear ISC Fault is located in the Internal Diagnostics Function menu. Does anyone know how to get to this menu?
gregworobets
Level 2:
Habit-Forming:
New Friend:
  • Expert 56 Answers
  • Posted on Jan 11, 2015
gregworobets
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
56
Questions
Helped
20919
Points
133
You will probably have to replace the ink loader
Dead Display on Xerox Phaser 6120
Did you receive any good solutions? I have a Dead Display on a Xerox Phaser 6120. Thanks!
Rick
[email protected]
1helpful
Powering Up My Xerox Phaser 8200DP
I assume no codes are coming up after leaving it on for a long time.
Most likely problem is the electronics module.
With the price of it you could buy 2 new dry ink phaser printers.
But what you are describing sounds like an electronics module issue.
1helpful
Xerox Phaser 8400 error code 37,004.40:27697
The majority of the time that code means the print head has failed.
That is a print head heater error.
You can find some places that sell print heads for about $150 , you would have to google the model number for that.
Xerox would charge $750 for a new print head, uninstalled.
Error code in Phaser 8550 window. ?:07,010.43:1362
The exact explanation per xerox is " The Printhead is stuck in the tilted position, and is not able to tile forward to the print position, due to problems.
This is usually caused by broken printhead restraints, of the machine got shut off in the middle of warming up, and the printhead is stuck to the cap wipe assembly.
Regardless the machines covers will have to be taken off to go any further.
2helpful
3answers
I have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Xerox phaser 8400 error
That is a print head tilt error. Either the print head pivot block is contaminated with ink or the wiper blade is tacked to the print head.
Let me know if you want to try to resolve it yourself, I will send you directions.
Xerox 8500n with error 13323.47:23971
13,323 is a Printhead Reservoir Temperature Faults . One of 3 things. In order of likeliness.
1. Print head has failed
2. Cable to the back of the print head is loose.
3. Electronics module has failed..
What that code means is that once the ink melts and flowes into the print head, the print head is not maintaining the proper temperature.
Xerox phaser 8400 error code
That code is a jet heater code.The most likely problem is a bad print head, the second most likely bad item is the electronics module that supplies the 40-50 volt source to the print head heater.
2answers
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Printer error meaning
I found a couple of references to the error ?07,010.43?, it?s a generic message with lots of possible causes. Xerox?s official web site says to turn your printer off a contact their technical support. I did find one reference that said for them it turned out to be a wiper assembly stuck between the print head and the roller. I?ve never owned a Xerox printer (I?m an HP guy) so I can?t help you beyond that. Xerox?s support site for the phaser series is here: http://www.office.xerox.com/color-printers/phaser-8500-8550/sprt-enus.html
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
