My Mitsubishi Electric Mr. Slim leaks after about 30 minutes
there no other way to repair that leaks other than you call an ac technician from service center and they will find it to you because there are special leak detector they will use to find where that leaks was and they work it using oxy acetylene welding to patched that leak,after patching they take a leak testing using high pressure equiptment to leaks test the system.so they can charge free from leaks,leaks should be stop because to protect our ozone layer.regards
SOURCE: air conditioning unit leaks
It sounds as if the unit overflow tube has disconnected. You may need to turn the electric off to unit, take the plastic housing off and see if the tube is still connected.
