SOURCE: replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
SOURCE: defective lid switch
you can bypass the lid switch,remove thw 2 screws on the console one on each side,flip the console up,you will see a 3 wire jack in the middle on the washer,disconnect the jack,the wires going to the console clip the 2 outside wires leave the green and wire nut the others together,plup back in and your done,let me know how you do-mike
SOURCE: how do I get to the lid switch to replace it on my washer
Pull of the end caps #14 & 11 on the diagram. Remove the screws and the front panel will flip up. Then there are 2 clips connecting the bac to the cabimet. Snap those out and the the WHOLE front of the machine comes off if you tilt it forward. Go to sears.com and parts to bring up any model for anything and you can kind of see how things go together. Good luck.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11022852100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00002&componentDescription=CONTROL%20PANEL&documentId=P0103381&backToLink=Return%20to%20Sub%20Components%20list
SOURCE: can't get top off kenmore washer model # 110 22852 100
No problem. What you want to do is this, remove the screws from the back panel first to remove that metal plate protecting the wires. Once off you need to take off the two covers on the sides of the control panel. There is one on each side, just pop them off. Once off you will see there is a screw under there holding the control panel in place. Remove the screws and that will lean back. Next take a flat head screw driver and put it under the lip of the lid on the front of the washer. I mean the lip that is about an inch down from the top on the front. Pry up and the whole lid will pop up. You will see the lid switch there held in by a screw, follow the wire to where it plugs in and unplug it and replace with the new one. Let me know if you have any other questions and if this was helpful to you. Always happy to help and good luck.
SOURCE: Kenmore 80 series lid switch
The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch DOES require replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
