Managers and Engineers usually need to present something using PPT, but there are many files are designed as PDF format, so they just use PDF file for presentation by maximazing PDF format, Firstly it is not as vivid as PPT and secondly, if one page of PDF is too long, audience could not see the lower contents in one screen.
Actually, there exists an application named
PDF to PowerPoint Converter by which you can convert PDF to PowerPoint for presentations. All the elements will be prefectly reserved. Here are the steps:
Step1: download the program and then install it.
Step2: Launch the program and input the file, or directly drag them into the panel.
Step3: Customize the path and then clike convert. work will be done in seconds.
Notes: You can batch,partial amd right-click convert PDF to PowerPoint, and it also supports encrypted PDF conversion.
