Question about Toshiba 32A33 32" TV
Where do I plug in the cable wire in the back of a Toshiba Reza tv
Where exactly is the cable impute on the TV
    Top Expert:
  • Toshiba Master
  • 76,204 Answers
At its ariel input socket itself.
Posted on Oct 18, 2014
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 121 Answers
SOURCE: Toshiba tv 32ax60 3 thin wires disconnected
belive your referring to rf converter assembly. entire unit can be replaced  or if threaded end pulled out can be repaired. dont understand 3 wires unless worked on previously. avg shop prob min bench to repair. .
Posted on Dec 03, 2008
gopakumarg43
  • 76204 Answers
SOURCE: toshiba cx36f67 tv - having problems with cable
Download the user manual to your set, and refer it about what you are missing. To download it, click here.
Posted on Jun 04, 2012
How to get video from dvd to tv
Use HDMI wire if you have that option than simply tune TV to HDMI 1 or HDMI 2 etc depending which one you connect it to .
OR. analog ( R C A ) cables analog. Output from DVD player to imput tv """ red is right white. Is left sound. Yellow is video pay attention to where you are plugging on TV.video 1 or 2 or 3 Since you will have to go to ( video. Or imput ) on your TV to access the DVD player. Another words your cable box is a TV imput . You're doing is also a TV imput You have to tune it to be able to watch it
Feb 16, 2015 | Universal 40-42 Inch Flat Screen Panel...
Our toshiba rezga 47lz196 colour is off. There doesn't seem to be any red. All the skin tones are green. Blue shows up but all the other primary's are green. We have green, blue, yellowish, black and...
There are only two possibilities for this problems for this tv.One: the tv incomming broadcasting signal cable wire that is plugging into ur tv Tuner signal board could be bad.U can test this out the incomming broadcasting signal cable wire is good or bad pretty easily by just plug it into another tv to find out the incomming signal cable wire is bad or good.Two: If the tv incomming broadcasting signal cable wire is good by plug it into a another tv.Than ur tv the tv Tuner signal board is the causes and the problems.The tv Tuner signal board CPU chip is bad.U can do some mechanical work like take things aparts and putting it back together again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 27, 2011 | Toshiba 47LZ196 47 in. HDTV LCD Television
I have a toshiba 32c100u tv i dont see exactly were to plug all white and red wires
red and white colored plugs are for audio, red it right channel and white is left. Plug your DVD player (if that's whay you have) into the red and whte on the tv, some tv's only have one audio in and its usually white, in this case plug in only the white wire from your player. the yellow plug is for video and you should plug that into the yellow jack on your tv. If you tell me exactly what you are trying to plug in I can help you better.
Mar 16, 2011 | Toshiba 32C100U 32 in. TV
The volume doent work when using the remote. I have tried the cable remote and the original tv remote and the volume works at times but less and less.
Try imputing a different toshiba code into each of the remotes. 0156, 0060, 0154. If that does not help, then unfortunately it is your tv.
May 14, 2010 | Toshiba 36A41 36" TV
TV picture jiggles frequently. Cable service. Is set getting ready to quit?
Mine did this...jiggle the cable imput and watch the picture to see if it flashes. Mine did so..the cable imput is the prob
Jul 30, 2009 | Toshiba CZ27V51 27" TV
DVD VHS Recorder setup.
hi there, a little late.....but here we go........do you have cable? if yes connect the cable from the cable box out to dvd in and connect the dvd out to tv in.......pls note the dvd and tv must be set/tune to ch #3.(and you cannot record HBO)......you dont have cable just tv and dvd you need rca wire (red,white & yellow) also the F connector wire....in back of dvd connect the 3 wires audio in video in (is your tv/monitor a flat panal these connections might be on the side) if not its in the back plug in to out on tv....(this is so you can record)....plug the F conncetor wire from dvd to tv......on this connection you can set the dvd to ch #3 or any ch you want to record...........
Jul 19, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Toshiba 9" TV/VCR W/CAR AC/DC - No power when on battery
I would check on the inside for a disconnected wire or loose connection at the Dc imput if it still works on ac. You can most likely get a service manual at http://www.servicemanuals.net/ if the wires are intact on the DC imput and the jack itself fits secure to the adapter. Hope this helps
Oct 24, 2007 | Toshiba 9" TV/VCR W/CAR AC/DC COMBO...
My 1999 TOSHIBA TP55H60 picture is not clear.
When is this happen? almost 8yr old the unit. In this case did u change the lamp bafore? Its seems that the lamp is dying. Try to use a DVD as ur imput and post here if it had a diff.? Use Audio/Video input instead of Coax (Cable). Hope this may help you
Aug 13, 2007 | Toshiba TP55H60 55" Rear Projection...
Imput channel or imput switch
if you scan down below channel 2 doesn't video show up? otherwise there should be a input / video button
Dec 31, 2006 | Zenith B27B40Z 27" TV
Toshiba 32A33 32" TV Logo
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
