SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
By default the AE/AF Lock only holds while you hold down the AE/AF Lock button on the back of the camera. If you've changed the configuration so that this button locks the AE/AF, you can unlock it either by pressing the button again or by turning the camera off and on again.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
back up your data first,thenyou reformat the memory card in the camera.i guess you have formatted the memory card in another device.canon cameras generally do not accept cards that have been formatted in another device.then sitch off the camera and reinsert the memory card.
Well, what i could read is the whole thing. But, i am guessing that ur camera cant take a pic cause the card is locked. Email me if u need any more help. Or u r lonely. And dont worry, i am SUPER nice. my email is [email protected]
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
remove the memory card out of your camera and look to the side of it.. there is a little switch on the memory card that locks the card... try that first it might not be your camera... :) good luck :)
The camera memory may "lock" as it reaches its limit.
With the camera disconnected from the PC, and on battery power, turn off the camera by closing the lens cover. Remove and reinsert the memory card. Now turn on the camera -- it should power on properly.
