HOW TO CLEAN CANON DR 1210-C SCANNER GLASSES CLEANED
SOURCE: Canon Scanner
Scanners can be taken apart to be cleaned:
'You want to clean the inside?'
'Well, its dirty ikayak, thats why.'
Ok take it apart, remember the screw sequences; that aint hard normally for scanners.
Put it this way there aint any little brushes or nanobots to clean it for you in there... you gotta do it manually. Use something alcohol based to lose smears and actual residue. It its dust then use a hairdryer and a soft SOFT brush that doesn't have any dust on it itself... you'll just make it worse.
I hope your scans are clearer now!
SOURCE: canon scanner lide90glass is broken where can i buy a replacement
I suggest you to replace complete scanner instead of purchasing a glass, bcoz this will cost you more, and more over less possiblities that it will work.
SOURCE: Canon DR-2050C Scanner gets verticle line down image
I have the same issue with mine and there are 2 image sensors on this scanner. 1 in the back that you will see when you open the front that has a meteal shield covering the top half, and one in the fold out front that faces the inside. These are the "glass" sections everyone is refering to. Problem is, they are plexiglass, not glass and mine has a tiny scratch in the lens that is causing the line. This could be your problem. find the lens and use a LED flashlight to inspect your lens for scratches. If its scratched like mine, the entire module has to be replaced to fix it. The canon part number is MH7-7038 and they range from $125-$160 if you replace it yourself. The one in the front is easy to do, but the back one is a little tricky. Hope this helps. E. Alexander, Field Tech, Cummins-Allison
SOURCE: canon dr-7580 scanner how to initialize cis
Hi, You may need to calibrate a new CIS with new Assembly. Later on this new assembly can be removed and your old one will do. Assembly means solonoid+ shading sheet. This will work for sure Samir Dhingra 9820800633
SOURCE: computer not finding canon dr-3080c scanner,
Please check if you have installed 'Driver' without which the Comp cannot recognise the SCanner. (Driver is the software interface when two hardwares are connected).
S. Mohan
