You may have entered the wrong passcode too many times. The only way to recover this is to connect it to your PC with iTunes and restore it from a backup. You need to do this from the same computer you used to sync it to.
This means you will need yo take it to.an Apple store and verify that you are the owner. They will usually unlock it. They might do it by phone. Thats the only way as it prevents theft.
If you're having a problem with your Apple ID, go here: Apple My Apple ID. If you're talking about your screen lock code, you'll have to hook it up to a computer, open iTunes on the computer, and click "Restore iPad from backup" if that option is available.
This works with devices having physical home button
1. Press the power button and the home button together
for a while, long enough until the screen appears with Android bot and a
progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
Note: I Use My Tablet SUNBERRY, and reset my Tablet Turn Off your Tablet and then Press Power + Volume Down (Press up Factory menu Show)
If you use Android 2.2 (Froyo) Press Wipe data / Factory Reset -> Yes, Delete ALL user data -> if Finish press Reboot Now
If you want more other andoroid OS and other tablet visit my Blog you can see how to Reset android with video
