<!-- from fixya rte -->How do I add a contact name and number? - Samsung Galaxy S Iii S3 Gt-i9300 16gb Marble White Gsm Factory Unlocked Gsm I9300 S3 3g Hsdpa 850/900/1900/2100 - Pre-order
Add a New Contact
Step 1
Touch the "Main Menu" soft key on your LG phone, or use the directional keys on your phone to select the "Main Menu" option.
Step 2
Touch or select the "Contacts" option to access a menu that allows you to add a new contact. Select the "New Contact" option using the soft key or directional keys. This action opens a blank contact template.
Step 3
Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Add the contact name in the same manner. Touch or select "Save" to complete the addition of the new contact.
Add a New Number to an Existing Contact
Step 1
Touch the "Main Menu" soft key, or use the directional keys on your phone to select the "Main Menu" option.
Step 2
Touch or select the "Contacts" option. Scroll through your contact list and select an existing contact to whom you want to add a number. Touch or select the "Edit" option.
Step 3
Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Edit the contact name in the same manner if desired. Touch or select "Save" to save the new number under the existing contact.
There should be an icon you can touch that will bring up a menu with "Edit." On my Moto G, it's three square dots stacked vertically in the upper right corner of the screen when I'm viewing my own contact info. Once you are in "Edit" mode, you should be able to add your name and other info as you wish.
Follow these instructions to add new contacts on your Nokia Lumia
On Start, swipe across and tap People.
Tap the New icon (+) at the bottom.
Tap Name to add First name, Surname, Title, Company name etc then tapSave.
Tap Phone to add a contact number and tap Phone number type to choose the type of number then tap Save.
If you wish to add further information such as an additional phone number or an email address, tap to add more details or press Save to store the contact to the People Hub.
You need to add the number to your contacts and also add the name of the person. Then when a TXT comes in the phone checks the number against the contacts and if it finds a match it displays the name.
check your phone memory limit may be it is full.
if it is still empty u need to reset all settingms of your cell phone to factory defaults.
Go to setttings then reset your celll phone.
but i think your cellular limit is over for save new contact check it .
I got a better solution for you. Its because the iphone is not designed for Australian phone numbers. Mine was the same.
On your installer add the source installer.iclarified.com
Then add a package called appsupport 1.1.4 and voila, your contacts will match up with your sms's and call logs automatically
Create contact (Menu 2.3)
Use this menu to add a new contact to Phonebook.
Storing a number in the phone’s memory
1. Select Phone.
2. Change the settings or enter information about the
contact:
• First name/Last name: assign a name.
• Mobile/Home/Office/Fax/Other: add a
number in any category.
You can change the number type, or set the
number as the default for the contact by
pressing <Options> and selecting Change
type or Mark as default number.
• Email: assign an e-mail address.
• Graphic ID: assign a caller ID image to alert you to a call from the person.
• Ringtone: assign a ringtone to alert you to a
• Group: assign the number to a caller group.
• Birthday: enter the person’s birthday.
• Notes: add a memo about the person.
3. Press <Save> or [ ] to save the contact.
Storing a number on the SIM card
1. Select SIM.
2. Select New or Update.
3. Enter information about the contact:
• Name: assign a name.
• Phone number: add a number.
4. Press <Save> or [ ] to save the contact.
