Question about Home
How do I fix a toilet seat securely and the easiest way to line up the hinges so it does not slide everywhere. Thank, at wits end
What is the easiest way to align the hinges in the holes so it does not slide all over the place. I find aligning the hinges very difficult, thank you.
    New Friend:
  • 64 Answers
Some toilet seats are better than others, it is usually the long oval ones that love to slide sideway;s, spend a little more and purchase the more sturdy one..hope this helps
Posted on Oct 14, 2014
6ya staff
SOURCE:
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Posted on Jan 28, 2009
Anonymous
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
mfraitag271
SOURCE: Square toilet seat made by American Standard Model TL 235.
This guy Allen in NY has lots of odd seats. Try him 914-963-6895
Posted on Nov 09, 2009
Anonymous
  • 28 Answers
SOURCE: Toilet seat hinges are loosening
Most generic seats have a thin plastic cap that snaps in place over the bolt heads just behind the seat. Normally they hinge backwards so carefully pop them open with a flat blade screwdriver. Sometimes you can tighten the bolts from underneath even.
Posted on Feb 27, 2010
slebert
SOURCE: kohler lowboy toilet seat does not have bolts underneath
My wife wanted to replace our Kohler low boy with a self closing seat. We got a Westport whisper close with unlock-able hinges for easy cleaning. I followed the above advice to use brute force to yank out the Kohler bolts. I then used a hacksaw to cut the new plastic seat bolts so that they would not extend past the thickness of the porcelain. I drilled the plastic bolts thru so that a small drywall toggle bolt would fit thru. Use a washer to prevent it from pulling thru, screw on the toggle and cut off excess screw length so it does not bottom out inside the cavity. Insert the assembly in the hole and tighten. Snap on & lock the Westport seat and you are good to go!
Posted on Jul 03, 2010
Help. Porsches toilet. Trying to adjust toilet seat. The hinge cover is fixed so hard that it came off with the screws. Cannot access the screws as hinge cover is stuck fast. How can I remove it?
You can try using a putty knife to pry up the edge of the covers. The hardware often is less-than-durable plastic so the end result may be destruction.
Jun 06, 2016 | Home
Toto toilet seat slides to side
you have to tighten these from the bottom of the bowl...use open end wrench or cresent to do
Oct 28, 2012 | Toto Round Maple SoftClose Toilet Seat...
Toilet seat slide
try to tighten mounting bolts be careful not to over tighten may crack poclean also see if seat has rubber gromets between hinge mount point at bowl.
Oct 30, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Toilet seat does not wont to close only using about a month
seat hinges were tightened out of alignment. Loosen platic nuts and tighten snugly, rotate hinges to bein line and tighten
Oct 02, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
My toilet seat is loose but there are no visible external securing parts. Its a Banyo suite with gentle self closing lid mechanism. How can I tighten it up and secure it back in place?
where the hinges sit, use a small screwdriver and prise off the top chrome cover.Under neath are the securing screws for the seat. tighten these carefully until seat is secure, then replace the covers.
May 13, 2010 | Home
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
I have a nice white Bemis toilet seat on which the
most hardware or home stores carry replacement hinges also online sites such as the hardwarestore.com sells replacement -larsen 2pc white hinge part 14-1039 $5.99 ace hardware,home depot, lowes, local stores
Jan 22, 2010 | Bemis 200 Slow Regular Toilet Seat, White
Problem with seat hinges
The best fix here is to purchase two new seats which come with the hinges attached. they are easy for the home owner to install. You can get them at any home depot or lowes where u will have many choices of color, design etc. Be to sure to note whether your toilet seats are round or elongated as you will want a round sear for a round toilet and an elongated seat for an elongated toilet. get back if you have any questions. the new seats will cost 15-40 dollars each depending on which ones you select.
May 06, 2009 | Home
Dec 22, 2008 | Toto Aquia II Dual Flush Toilet
Home Logo
69 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
