I use a Transcend memory / wifi card. It not only is a good and fast memory card, but also acts as a WiFi hotspot and sends the pictures form the camera to a phone and or tablet (3 devices in the same time can be connected) The apps for the phone or tablet, IOS or Android are free. Check here how it works,
ask for SD card with WiFi. there are cards with 16 Gb and 32 GB Choose Your Country or Region
Although the Android phones and tablets can add (micro) SD cards, that will not extend the internal memory. You should see the SD card as a extra hard disk. Here you can hold pictures and music. As soon as you installed extra apps, and the phone or tablet is telling you the memory is full, you only can free memory, by deleting apps from the main memory.
If you thought I can buy a phone or tablet with less memory, because the SD cards are very cheap and will extend the internal memory, you thought wrong.
You can't transfer an app to the memory card and still use it as if it was in the main memory.
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
if you do not mind loosing any data press and hold reset button for 30 seconds will set back to factory default settings or snap case open and try cleaning button surface where it connects
Plug your camera into your tablet's usb port and transfer them, take the memory card out of the camera and put it into the tablet's memory card slot if they're the same size, transfer them by bluetooth, or download them to a computer, then send them to your tablet from the computer.
