How do. I open a Xbox 360 step by step portal to connect to internet
Here ya go, this is on the latest updated dashboard!
In the Xbox 360 Dashboard:
SOURCE: My Xbox 360 won't go ot the Internet
first i had the same problame with my x-box is you are using a hub router try putting it into pairing mode then search for networks on the x-box and this should resolve your problame
SOURCE: the internet is connected to the xbox but the xbox live will not connect
Restart your modem or router, give it 30 minutes, and try again. If you still are not on live just check the tips they give you
SOURCE: XBOX 360 LIVE Won't Connect
Is the modem also a router?
You need to login to the IP address of your device... if the modem is only a modem, try going to your own IP address.
http://whatismyip.com will help you find it. This may bring you into the settings of the modem. If it is a router as well, then you will need to go to your default gateway's IP address.
Go to start, then run.
Type cmd, then click ok.
type 'ipconfig' and hit enter. Look for your Default Gateway
type that ip into your browser (IE/Firefox/whatever) and login
adjust the MTU to recommended settings. If its at 1500, try 1364 of 1492
SOURCE: xbox 360 reads open tray and doesn't show game
Just keep closing and opening the tray, sooner or later it should read the disk.
SOURCE: XBox 360 won't play discs. It just says open tray.
Your DVD drive's laser is malfunctioning.
You have a few options:
1) Decrease the resistance on the laser to increase power, and it may be able
to read the discs again. A guide for that can be found here.
2) If that doesn't work, or you do not wish to do that, you can replace the
laser head all together. Replacements can be found on eBay. You can follow this guide
to replace the laser head.
3) You can replace the DVD drive completely, but it will require taking the
original drive's firmware and putting it on the replacement one. The guide for
Connecting to Xbox LIVE involves three basic steps:
