Door is rusted. What can I do about this?
Hello friend, thank you for your post!
I understand that there is rust on the door of your Frigidaire refrigerator. Typically, rust is not covered under the warranty and in most cases the door will more than likely need replacing. If you would like to get a part number and availability I would recommend contacting the manufacturer directly. If you would like for me to locate that information for you could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the inside wall of your fresh food side. I look forward to assisting you. -Matt
SOURCE: rust under water dispenser on freezer door
I had the same problem and I replaced the door. I also found out that this problem is cause by water going into the two screws in the back of the Water/Ice dispenser. He is right; it was hard, but possible. Be careful when removing the Water/Ice dispenser.
goodluck
SOURCE: Rusting of the door on a stainless steel refrigerator
True stainless steel will not rust, but it can get rust stained, which could be removed. Without any further info about your situation, I'd have to guess that you have a high iron content in your water supply, and thus rust issues with your sinks, etc., unless you have a good iron reducing softener and the water to the refrig is not running through that softener. Again, without further info, I'm guessing the rust issue is at or below the water dispenser area. Keeping the water from spilling over the drip tray will help. You might try Wink rust remover, but do test it on an inconspicuous area first to make sure it will not adversely affect the finish in a visible area.
