SOURCE: I just bought my wife a michele csx-36 watch. Its brand
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
SOURCE: The red bead (?) on the stem of my Michele CSX
I also chipped the enamel on the crown. You should take it to the place you purchased it and they will send it to Michele (actually Fossil) for repair. I had my Michele for 5 years before sending it in to have the crown repaired and have since lost the stem. Prior to that first repair, I did not have any issues with my watch. I really think that the parts used on my watch for the first repair were shotty. Very disappointing, but what do you do?
SOURCE: Had the battery replaced in
Loose cannon pinion or cannon driving wheel; the seconds hand represents the wheels in the back of the watch going around ok, but the power need to transfer through to the front of the watch somehow.
This is done by snapping/clicking two wheels together on either side of the main plate. The one on the dial side (cannon pinion) needs to slip to be able to set the time as the minute hand is set on this pinion. Im sorry, its time to see a repair guy.
Hope helps.
SOURCE: Can I replace the battery on my Michele watch
i recomend to send it to michelle company go to their website and print the repair form all you pay is 22.50
i went to the mall and asked the other day they wanted to charge me 60 dollars
also these watches have a waterproof seal and once open they have to make sure they make it waterproof again and im sure they wont do this just everywhere . so i rather go for sure with mw directly im sending mine this week by the way
SOURCE: MICHELE CSX HAND ALIGNMENT
You don't say if your "CSX" is a battery powered watch or a mechanical or windup type watch. The solution for a mechanical watch is take it to a watchmaker. If it is a battery powered watch you may be able to do it yourself. Not all work the same way so without knowing what a "CSX" is I will give you one way to try. Pull the crown out two clicksHold the lower button in until a hand moves.You have now selected that hand to adjustUsing the upper button now, press and adjust the hand until it lines up with 12Now hold the lower button againAnother hand should moveUse the upper button to adjust this hand to the 12 positioncontinue this until all the hands line up with 12Press the crown in and press the upper button,the chronograph hands should startPress the upper button again and they should startPress the lower button and they should all go to the 12 o'clock position
