SOURCE: Where are the filters in Hotpoint Aquarius WF340 washing machine
if you dont have one in the front under the lid your model comes with a slip on filter that goes on top of the aggitator you schouldnt run it without it because ge pumps have a tendacy to freeze up with the lint from your clothes especcially levis hope this helps
SOURCE: how do I find and clear the filter in Hotpoint Aquarius wf210?
pull machine forward andtilt back look underneath machine at bottom ofplastic tub u will c a black pipe leading from the tub t the pump unscrew from the tub end (put a bowl down first as water will come out)pull off pipe inside u will c a white platic collecter pull that out clean and put back together hope this helps
SOURCE: i cant find my filter
It is either behind the kick plate at the front or in the pipe on the bottom of the drum which runs to the pump.
This is acessed by removing the panel at the back.
Hope this helps & thankyou for using Fixya.
SOURCE: hotpoint aquarius extra filter
Normally in front of machine.Remove down plastic cover and then you see pump/filter,open and clean and make sure pump rotor is free to run.Jan
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
