Need instructions to reset this timer
There is no reset for 59017 timer.
Check if slide switch is set on timer
If timer is not rotating, then check circuit breaker, check wiring, replace timer.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#in-wall
http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
http://waterheatertimer.org/How-to-wire-timers.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: I have a Woods 59017
It sounds like the wall switch that you have already is a three way switch... the timer will not work in a three way application...
So... you cannot hook that uo to there and make it work correctly...
heatman101
SOURCE: Have used a Woods $59017
You can get the manual on the link below.
http://waterheatertimer.org/pdf/Woods-59017.pdf
SOURCE: need setting instructions for woods timer medel
You can get the manual on the link below. It will tell you how to set.
