Hold the volume UP botton down when it is OFF, then while holding that button down press and hold the power on button and keep both pressed for about 10 seconds. Then release.
hook it to computer and go to the kurio site and have them diagnose it or they will send you a box to send it to them to be fixed or replaced,tell them its less than 9 months old
Your tablet may need its battery calibrating. To do this run your tablet until it turns itself off, this will ensure that there is no charge left in the battery. Then leave it on charge until the battery is full. Normal battery use on modern devices like tablets and phones should be between 25-75%, with a calibration once every 3-6 months to ensure a good battery lifespan. If this solution does not work you may need to replace the battery.
Try cleaning the touch-screen with a tissue or touch-screen cleaning paper, then wash your hands and use a skin moisturizer on your fingertips. If it still doesn't work, something's wrong with the unit. The touch-screen should work down to the discharge limit of the battery.
Note: when you buy a new lithium battery or device that uses one, it is a good idea to charge it completely before using. Some types of battery charge controllers use this first cycle to calibrate battery parameters so you get optimum performance from the battery.
