Yes. It is available at most of the electronic spare part selling shops.
SOURCE: hi- I bought a used 37LC model (less than 1 yr
if the display says cable, it won't get over the air signal. switch the source to antenna, hook up an antenna and go through auto program sequence.
SOURCE: i`m an electronics tech that
hi,
CBPF6Z1KA8 may no longer available but:
CBPF7Z1KZA2
Main Unit | Main Board | Audio/Video Board | Tuner Board | VGA Input | Head
is still available:
you might also consider having a separate tuner or
a set- top box
But have a check on the VIF sections, it could just
be a cold solder joint or a possible setting on the
Circuits.
SOURCE: Sanyo Model Number DP26640 Channel search
HI,
Did your problem solved. if you Need any assistance feel free to conact back.
Ajin
