Model DMC-F515
Either of two ways.
If you normally download photos by taking the memory card out of your camera and putting it into a card reader, copy the photos from the internal memory to a memory card. See page 81 of the manual: http://service.us.panasonic.com/OPERMANPDF/DMCFS15.PDF
If you normally download photos by connecting your camera to your computer, remove any memory cards before connecting.
SOURCE: cannot transfer my internal memory photos into my sd memory card
if you insert the card and it would read the card immediately - not allowing you to see the pictures on the internal, that means the image storage is set to AUTO, you have to set it back to internal so you can copy them to card and just put it back to AUTO to reactivate the card
please follow this path:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
you're supposed to see the copy of pictures from your internal and pics from your card if there's any
you can visit www.kodak.com/go/manuals
SOURCE: internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
SOURCE: not able to download images from internal memory
Go into the menu and find "copy". Choose the option to copy from internal memory to memory card. From the card, you can download the pics.
SOURCE: internal memory full
i have this same problem i even tried formatting my memory card and my camera and it still wont recognize the card i inserted
SOURCE: I need to get photos
Easy...go into the menu and find "copy". There you will have the option to copy the internal memory contents to a memory card.
