Question about Kyocera "FS-3140MFP Printer, Copier, Fax & Color Scan 42 ppm"
<!-- from fixya rte -->How do i clear jam 20 in fs 3140 - Kyocera "FS-3140MFP Printer, Copier, Fax & Color Scan 42 ppm"
  • 295 Answers
You can find it on page 375 of the user manual here: http://www.manualslib.com/manual/450403/Kyocera-Ecosys-Fs-3140mfp.html?page=375
just continue with page 376, 377, 378 to follow the instructions ...
Posted on Oct 17, 2014
Anonymous
SOURCE:
Fs 3140 mfp error
Can you be more specific or provide error codes or messages?
Jul 04, 2014 | Kyocera FS3140MFP AllInOne Laser Printer
Where is a paper jam in the duplex cover
remove cassette inside underneath there is a green lever pull it down paper should be in there
Jun 27, 2014 | Copystar Kyocera Fs-3140mfp fs-3140 Copier
Fs-3140 maintenance reset
When you are in ready state, type 10871087 to enter the maintenance mode. Then type 251 to go in the section where clean the MK counter. (U251 Checking/clearing the maintenance count). Press Start to reset (if I remember correctly , you will need to type a new counter (000000), not just to clear the old one). After reset, you press Stop key to exit the submenu. Type 001 and press Start to exit the Maintenance mode.
May 14, 2014 | Kyocera FS Office Equipment & Supplies
Search Fixya...MIta 3140 wont receive faxes
make sure your phone line is plugged into the LINE jack, not the EXT jack
Jul 16, 2013 | Kyocera FS-3140MFP Mita FS-3140MFP 42 PPM...
FS-3140 memory full when scanning
change scan defaults to monochrome, pdf, and 300dpi or lower resolution in command center.
Feb 18, 2013 | Kyocera Copystar FS 3140MFP/DP copier
Paper Jam at back od Kyocera. How do i clear this?
The link below will take you to the manufature website where you can download the operators guide. On page 4-12 it explains how to remove jams from the printer to include pitures.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=12330&rid=12548
I hope this is helpful,
Shawn
Feb 12, 2011 | Kyocera Mita FS-1920 Laser Printer
Kyocera fs-1920 paper jams when page is half way out of top , when you clear it the paper has some grooves in ? does not happen every time and when cleared it is ok again for 3-6 pages
on the menu buttons on the machine..change the paper exit to go out the back.. if this solves the problem.. you might be looking into replacing exit rollers or fuser
Mar 09, 2010 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1020D process unit in two pieces
best thing todo is get a new PU-102, the gap between the drum and dv unit is to large and the toner is not transfering.
Dec 27, 2009 | Kyocera Mita FS-1020D Laser Printer
Kyocera "FS-3140MFP Printer, Copier, Fax & Color Scan 42 ppm" Logo
397 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
